codes
P1693 (M) DTC Detected in Companion Module A fault has been generated in the companion engine control module.
P1693 (M) DTC Detected in PCM/ECM or DTC Detected in ECM A 9Companion DTC9 was set in both the ECM and PCM.
Re: codes
Originally posted by okladodge
What does this mean P1693
DTC Detected In ECM Or PCM
http://www.troublecodes.net/chrysler/99-01trk.shtml
Basically you have a code that that can't be retrieved by the method you are using.
Most likely only can be seen with the official Dodge DRB Scantool which can talk to both the PCM and the ECM.
Or, you had a code at one time that cleared itself when the problem went away, but left behind the code saying there was a code.
phox
phox
exwrestler
02-05-2010 09:34 AM
sallyman1
08-26-2008 06:20 PM
StormTrooper
03-28-2005 09:17 AM
