code question?
Do you have any mods done to the truck? P0237 i believe is Map sensor voltage too low. Go to the cummins dealership (not dodge), pick one up and replace it, i think they're around $60. If that doesn't work you need to dig deeper, check fuel pressure, check and see if the wastegate is stuck open a bit etc...
O.T
09-06-2007 06:10 PM
CTD NUT
04-05-2005 04:45 PM
