code po122
Old 11-04-2006 | 01:33 AM
chadwick's Avatar
code po122
this evening when i left my buddies house to go home when i fired my truck up my warning light was on and i checked the codes when i got home and i got p0122 Throttle position sensor voltage low. when i was driving it over the my transmission started to hunt between gears. i recently did the ats fix for the hunting problem and it did go away. So i am geussing maybe one of my connections came loose or at least i hope so. wish me luck
Old 11-04-2006 | 06:42 AM
crobtex's Avatar
Did the "fix" have anything to do with the APPS or just the tranny?
Have you tried the APPs reset procedure or the recal procedure ?
Old 11-04-2006 | 08:28 AM
blackdiesel's Avatar
Registered
do the reset as stated, but if that dont fix it, before you run out and buy one, test it out with a meter frist. I know of two (mine and another members) that had that code, and it was the ECM that was not reading the signal.
Old 11-04-2006 | 10:37 AM
chadwick's Avatar
where is it at and you talking about testing the throttle position sensor itself if so how many volts should it have
Old 11-04-2006 | 11:10 AM
crobtex's Avatar
Click on "procedure" above. You'll have to scan down the page to get to the post with the "cal" procedure.
Old 11-04-2006 | 02:19 PM
chadwick's Avatar
ok well i found out that the negative cable that comes from the computer black with orange tracer had come disconnected from the negative terminal. i geuss i dident tighten it good enough when i changed my battery terminals. Thanks Crobtex and Blackdiesel for the help
Old 11-04-2006 | 02:57 PM
crobtex's Avatar
Cheap fixes are hard to find. Hope all is well.
Slugblaster
07-30-2012 09:11 AM
nasty01cummims
03-20-2009 03:02 PM
STACKED
03-04-2007 07:13 PM
Terraizer
12-14-2005 04:56 PM
CTD NUT
04-05-2005 05:45 PM
