Clutch, No Clutch?
Clutch, No Clutch?
2002, 5 speed, 2wd.
97,000 miles
The truck runs great, but every once in a while, limp clutch pedal?
Pump it, back to normal?
What could it be?
No loss of fluid?
Master cylinder, on the clutch, is the only thing I can think of.
Thanks, in advance.
97,000 miles
What could it be?
No loss of fluid?
Thanks, in advance.
Hyd clutch assy is failing. Recomend replace as one piece assy from Dodge. Can get a aftermarket from Southbend clutch with slightlly larger cylinder for a few bucks more. Don't try replacing just one piece. Hard to bleed and may get wrong part. JMHO
He's talking about the master/slave combo that Dodge sells. You get the master, slave, reservoir, plumbing... all pre-bled and ready to go. It's about $200 from Dodge. South Bend Clutch sells a similar combo for a little more money.
Dave
Dave
WACTD
07-25-2006 11:41 AM
Fishbait
06-06-2006 12:34 PM
