Checking out a truck to buy
On the whole lift pump/Vp44 issue, Dad is checking out a couple of trucks to buy, if the lift pump is out, it should not fire off in the first revolution on the engine correct?? Should be a little sluggish starting?? Is the pump supposed to make any noise at all when the key is turned on before ignition?? Is the noise if any hard to hear??
Kip
Kip
Try bumping the starter and see if the Lift Pump runs. It shoud run for about 30 seconds. turn your key to start just long enough to bump the engine dont crank it over untill it fires. the LP is fairly noisey you should have no problem hearing it.
Riflemanusmc
04-11-2009 12:13 AM
dieselfan
07-25-2006 11:53 PM
12PACK
04-29-2005 10:26 AM
