Changing Xfer Case oil
I'm looking to change all the fluids on my '01 drivetrain.
DCX calls for ATF+4 for the Xfer case oil.
Can't find this stuff at any auto parts store.
Is it only available at the $$$ dealer?
What did the '98 models use in their Xfer cases? (same xfer case, right?)
I used Dexron III in both of my trucks per the owners manuals.
See if this link helps you.
Transfer case specifications
Also I had good luck with this trick.
T- case drain trick
Hope this helps.
T- case drain trick
Hope this helps.
In a transfer case, I think most any ATF will work. There's no clutches, shifting etc.
That said...Redline C+ meets +4 specs per Redline. That's what's goiing in mine. I get it for < $7 per qt.
i went to my dealer for the +4 and it was only $16/gallon. i was happy. changed the tranny fluid and filter. didnt feel it was worth the headache to put in the wrong stuff.
Steelheader1
12-04-2006 12:30 AM
4x4dually
06-20-2006 08:38 AM
guidster
06-06-2005 11:16 AM
