Changing both batteries???
Old 02-14-2007 | 04:42 PM
NCTURBOS's Avatar
This may be a stupid question...
Is there a certain order for changing out both batteries in our trucks?? One at a time, both, drivers side first or passengers???
TIA,
K.
Old 02-14-2007 | 04:47 PM
JPR Ram's Avatar
From: My head lays down in Murrieta, but the day light hours are spent in San Diego, Ca.
doesn't matter..............
Old 02-14-2007 | 04:56 PM
Rocky5.9's Avatar
The order doesn't matter...just don't send me the bill.
Old 02-14-2007 | 04:59 PM
Geico266's Avatar
Change them both at the same time, don't just replace one.
Old 02-14-2007 | 05:01 PM
JPR Ram's Avatar
Yeah, thats a sure fire way of killing a new battery.....fast......The old weaker one will be a constant drain on the new one.......
Old 02-14-2007 | 05:13 PM
PChouinard's Avatar
Yup, if ya need to change one, change both. If your just talking about the order, it doesn't matter as stated above. If you disconnect both at the same time, you reset your radio stations and I think the ecm/tps? Is that correct guys?
Old 02-14-2007 | 07:55 PM
1-2-3's Avatar
Just a plain ole guy
Change both, and disconnect them one at a time. I slip the positive cable on the disconnected battery inside a ziplock bag so it won't ground the hot end connected to the other battery, and that way you don't loos all your radio presets and clock settings.
Old 02-17-2007 | 09:13 PM
john1's Avatar
doesn't matter
Old 02-17-2007 | 09:33 PM
fbx22's Avatar
when changing 1 both should be changed just like a burnt out light
Old 02-18-2007 | 09:26 AM
RowJ's Avatar
I like Charliez's idea. One at a time! Keeps radio settings (which on Sirius Radio's is a pain to redo) and doesn't erase odometer... which is important for me.
But, to answer original question (again) ...doesn't matter as long as you do both.
RJ
Old 02-18-2007 | 10:43 PM
PChouinard's Avatar
disconnecting both batts will not erase your odometer.
Old 02-19-2007 | 12:38 AM
fbx22's Avatar
no because if it was that easy there'd be a lot of low miled dodge trucks at the used car lots
Old 02-19-2007 | 08:51 AM
RowJ's Avatar
How about..."does not erase TRIP odometer.
RJ
04ctd
05-07-2011 02:08 PM
ARIZONACLASSIC
08-29-2010 09:08 PM
jonesm8
37
10-11-2008 10:01 PM
sodbuster03
10-09-2007 04:42 PM
1sttruck
01-09-2004 10:56 PM
