Carter Fuel Pump - P4601HP
I use the Carter 4600. It is a 7psi pump instead of 15-18psi that the 4601 is. I don't like the idea of running my fuel pressure above 20psi. Many people do run 20psi plus without problems............ Just not for me...
Good luck, Phil
On edit: I should note that I have the in tank lift pump. Total fp at idle is 15psi.
Good luck, Phil
Ideal pressure is 15 PSI... Overflow valve opens at 14 PSI... So your covered in all angles good...
You might want to check out the Campaign pump...
http://www.frontiernet.net/~mopar197...paign_pump.htm
vzdude
10-28-2007 02:16 PM
Big Smoky
03-23-2006 12:11 PM
