Can't get brake drum off!
I need to get my right rear brake drum off to see what is causing it to lock up and squeek. I have tried beating it with a hammer, soaking it in WD40, and putting it on jackstands in second gear and stomping on the brakes. It is irritating me to say the least. Any suggestions would be appreciated.
Try turning the brake shoe adjuster on the backing plate.
Its on the bottom, behind the little rubber grommet.
Turning it one way will tighten it and the other loosen.
I don't remember whitch way, but you'll figure it out.
Hope your drum isn't so grooved on the inside that it actually key locked on to the shoes.
Good luck................Jim
jack up the rearend start truck up (with tires off) shift from drive to reverse while slamming on the brake peddle, should come off very easily then. if that dont work your gona havta bust the star wheel in the opposite direction to move the shoes away from the drums. been doing brakes for 20 years, the above directions have allways worked for me.
Thanks for the advice guys, it finally came off after a few more tries. I think my automatic adjuster thing was over adjusting and causing my brake to drag and so on. We'll see.
Totallyrad
07-19-2011 07:41 AM
Need95-00CTD
10-03-2007 12:18 PM
