Can pluging in a motor cause the block to crack? non-53
True...ill look them up. Just need a block....if the old dealer trade is not in the works......i dont suggest that...but.......plus i got my eye on thoes 180 HP injectors and Drag Comp!
For all those that subscribe to the freeze plug thery ....please let it die,do not tell your offspring that as it is not true! Like said they are in reality "sand plugs" to get the sand out......Not a safty net for freezing.
Allso guys you gotta have the anti frees full for heater to work right. As it heats the hot fluid rises. As it rises it goes over the top and starts to circulat threw motor. eventually warming all fluid. But if level is down even if heater is submerged ,the heater will heat water around it but not start a circulation action. thus freezing at far points from heater????
taken5875
27
01-09-2007 06:57 AM
