Caliper Bracket Bolts
Working on replacing hubs.
My truck spent a couple of years on the coast and the two bolts that hold on the caliper bracket seem to be pretty well frozen on there. I have been soaking them with PB blaster for the past couple of days with no luck. The heads on the bolts have started to strip, so I don't want to put any more pressure on them.
questions:
1. How much heat should I put on them to try to coax them out?
2. Where do I apply heat? Head of bolt? Around the bolt on the caliper bracket?
3. Will tapping with a hammer loosen any of the treads?
any other suggestions?
questions:
If you can I would get an impact on it pronto. If you can get it to a good shop they can probably put some heat to it and smack it off with the impact.
Any other way may cost more headaches
Diz
Diz
grishfish
08-23-2009 09:54 PM
1985cucv
03-17-2009 09:06 PM
SolarYellow05
05-02-2006 09:46 PM
