(CAD) Dana 60 inner Seal Replacement
OK...looks like i am going to get to help a friend out with this. BUT i am going to Texas to do it..so time will be tight. I know how to pull the axles out with the hubs...that is not a big deal...but that is as far as i have gotten into this axle.
I hear the Carrier has to come out to replace the seals on the CAD D-60. BUT how do you get that half shaft out from the CAD? The manual (which i have been reading the last few days) doesn’t really come out and say. Im guessing you have to take the VAC CAD motor apart to get to it?
Do you have to have a case spreader to get the carrier out? I know it calls for the Dana 80 to have one...but i have pulled carriers out without using one.
Any tips tricks and pics someone might have would be helpful. ALSO any parts that we will need. Thanks!
After i get done with it...i will do a write up and post it up here....
Is there a C-clip in the carrier i need to remove on the inner half shaft first?
I dont want a situation where i can get the seal out.....but cant get it back in because i didnt bring the right tools with me.....
Thanks!
Thats an awesome link, really explains pretty much everything. One thing I dont understand, is there nothing supporting the passenger side axle shaft except the seal. Mine flops around all over the place, but the seal is bad.
Keep us updated Diesel-Dan, I'm gonna have to do mine real soon. Not looking forward to it.
The pass. side axle shaft is supported by the fork of the CAD clutch and the sliding part when it's assembled. The outer half of it is supported by the inner half. (There's a bearing in some of them looking quite like a clutch center bearing. There should be no visible slop.
The procedure described in the link is good, couldn't have written it better myself. I used a small air grinder with a brush wheel that is bigger than the grinder body itself to clean the axle tubes. I zip-tied the lever to the run position, shoved the grinder into the tube with the air hose as far as I needed it and then connected the air. The grinder did it's little happy grinder dance in the tube and I slowly pulled it out with the hose until I could grab the grinder housing. Results in a nice clean axle tube, a beaten up grinder and a very dusty shop.
HTH
AlpineRAM
HTH
AlpineRAM
HTH
AlpineRAM
HTH
AlpineRAM
HTH
AlpineRAM
HTH
AlpineRAM
Cool idea, I bet it worked like a charm too...
kawi600
12-15-2007 11:54 PM
