bunch of codes
bunch of codes
Have a problem with the cummins, was pulling a load of calves to the sale today. Got to the top of the mountain with no problems, started down the other side and started coasting. Went to give it some throttle and no go.
Thought i might have a plugged filter, changed that and still did'nt fix the problem.
Truck starts and idles good will take throttle to 1200 rpms, then it cuts out, jumps,bucks, no response.
I have unhooked the edge comp and went back to factory, still does the same thing. will start and run rough for a couple of minutes then levels out. give it throttle and it will spit,sputter and rev up every 5 seconds and back to sputtering.
codes are P0237, 0238,0251,0252,0253,1688,1689. Any one want to give me the bad news.
was able to drive it back home as long as i kept it 1200 rpms or under.Anything over that and it spit and sputtered.
Fuel pressure never went below 10psi.
truck is in my sig.
truck is in my sig.
truck is in my sig.
truck is in my sig.
voltage.
P0238 (M) Map Sensor Voltage Too High MAP sensor voltage input above the maximum
acceptable voltage.
P0251 (M) Fuel Inj. Pump Mech. Failure Fuel
Valve Feedback Circuit
Problem sensed with fuel circuit internal to fuel injection
pump.
P0253 (M) Fuel Injection Pump Fuel Valve
Open Circuit
pump.
P1688 (M) Internal Fuel Injection Pump
Controller Failure
Internal problem within the fuel injection pump. Low
power, engine derated, or engine stops.
P1689 (M) No Communication Between ECM
and Injection Pump Module
Data link circuit failure between ECM and fuel injection
pump. Low power, engine derated, or engine stops.
It definitely looks like it's time for a new VP44...
However, it has been my experience that when you get that many codes all at once, it is very probable that the issue is electrical, IE a bad ground somewhere in the system. Might want to start there...
changed both batteries a couple of weeks ago, i know they were corroded pretty bad. cleaned all the terminals when batteries were replaced. have dialetric grease on all connections.
It's cheaper than replacing the VP44 at any rate. I do remember several instances of people replacing the injection pump only to find out it was not the culprit, and at about $1000, it's not an easy pill to swallow.
i plan on checking all the grounds and pulling the map and doing a apps reset just to be sure.
I had some trouble with the edge connections at times, a little jiggle to the box would usually jar ir enough to correct. This time it did'nt correct it.
I have unhooked the edge just to rule it out.
I probably wont peirce the new pump if i wind up needing another.
qzilla
04-09-2010 07:55 PM
sallyman1
08-26-2008 06:20 PM
