broken exhaust manifold
My exhaust manifold split right down the middle where the turbo mounts.
I was wondering if this is a common problem. Where is the best place to buy the replacement? New or used? Truck is an all stock 2000 3500 auto.
Thanks; jmack9288
Thanks; jmack9288
Yes it does happen on these trucks. You can by a used one, thats what I did short on cash at the time, A new one from cummins that could more than likely crack, or buy an aftermarket one such as ATS its a 3 piece, there or several different aftermarket ones
Go with a 3 piece set up. Don't waste your money on a manifold that will crack again.
Fairly easy install, comes predrilled for a pryo. Helps lower EGT's also.
http://www.atsdiesel.com/ATSWebsite/...ExManifold.asp
crack
Rpainter
21
03-08-2008 02:36 PM
Dusty Ratcliff
04-02-2006 11:08 PM
