Brand of lift pump..again
#32
Guest
Posts: n/a
#34
That depends, if you have any problems with the draw tube or not. We went round and round with that darn thing. I would plan on the better part of a day to do the install.
#35
I didn't have to pull the bed to install a new pickup in the tank with the 100. The 150 unit requires you do this, and that would make it pretty much an all day job.
Compared to a stock pump? A stock lift pump I could swap in about 45 minutes or less, since I've done it a couple times before. The only hassle with that is really where it's located, helps to have long arms.
So, quite a bit longer to install than a stock pump, but well worth it.
Opus
03-14-2011 01:12 PM
Steven K
06-04-2009 10:32 AM
