Brake Rotor Info Please
Old 04-06-2010 | 03:35 PM
pogo1's Avatar
Hey Guys
I have a 2002 Cummins 2500 4X4. I've got some wear on the drivers side rotor... What is involved in changing out the rotor? Easy Job... No special tools required?
Thanks!
Old 04-06-2010 | 04:17 PM
ado2b1's Avatar
Should by easy enough but time consuming especially the first time through. I think you can remove the rotors without taking it off the hub assembly. Air chisel with point attachment, line up each stud and press out past the hub assembly flange. If you can't do it without taking off the hub assembly (I can't recall off the top of my head), then search on this forum for hub assembly removal (or ball joint removal). It again is fairly easy with knowing the proper tricks. Good luck.
Old 04-06-2010 | 08:22 PM
nickg's Avatar
its a slip on rotor, no need to pop out studs, just unbolt caliper, unbolt caliper bracket, (think you need a 12point 16mm socket) slide the rotor off (might need a smack with a hammer) and re-assemble in reverse order
Old 04-06-2010 | 08:45 PM
diggerfan99's Avatar
I have a 99 4x4, I thought you had to press the rotors off the hub assembly? Did they change it after 99?
Old 04-06-2010 | 10:20 PM
torquefan's Avatar
Yes, they changed the brakes (front and rear) , knuckles, and ball joints for the 2000 model year.
Old 04-07-2010 | 12:29 AM
Russ Roth's Avatar
What Nick said.
Old 04-08-2010 | 10:14 AM
ado2b1's Avatar
Good old Dodge. The more I work on my '99 the more I think they had the "D" crew of the design team make my year up... In that case, OP, you shouldn't have any problems at all. Enjoy your 30 min. brake job.
kawi600
32
10-17-2006 08:12 AM
7mmrum
36
09-08-2004 12:09 PM
Caincando1
10-12-2003 02:25 PM
Quick Reply: Brake Rotor Info Please
