Boost pressure and EGT readings
Old 05-02-2005, 08:34 AM
xp8103's Avatar
New Turbo?? Was: Boost pressure and EGT readings
Now that I have my EGT and boost gauges in place, I am struggling to keep my eyes OFF them while driving. But I have questions now, showing my diesel performance ignorance.
What should I be seeing for readings?
WOT, I am at about 24 pounds of boost? I tapped into the intake via the plug on the DS, back end of the engine? Since the gauge is 0-35 psi, I assume that 24 is a good number. My mechanic friend who helped me put it in (ok.. I helped HIM) was unfamiliar with the readings as well. He's used to 10-14 pounds seen in car turbos.
Also, the EGT needle is a busy little bugger. Cruising at 74 on the interstate unloaded I was up in the 800 degree range or so. At idle this morning, was somewhere in the 250 - 300 range?
Old 05-02-2005, 11:08 AM
BigBlue's Avatar
Your boost sounds a little high. Do you have some sort of fueling box on your truck? Most stock trucks run around 18-20 psi. Your EGT's sound normal for a pre turbo gauge. You did mount your probe pre turbo right?
Old 05-02-2005, 11:45 AM
xp8103's Avatar
No intake side mods at all.
EGT is right on the rear runner of the exhaust manifold.
Old 05-02-2005, 12:38 PM
CTD NUT's Avatar
24 psi is high for a stocker.....it should be gated for 20 psi - 22 psi tops.....do you have a 0234 DTC? ....might want to check for that code - it's the overboost code and it could mean you have a sticky wastegate......the ECM will defuel past 20 psi......
Old 05-02-2005, 02:06 PM
xp8103's Avatar
Could my gauge just be off a bit?
How do I get the codes to read again?
Old 05-02-2005, 03:56 PM
phox_mulder's Avatar
Turn the key to on then off then on then off then on and codes will appear in the odometer.
phox
Old 05-03-2005, 06:51 AM
xp8103's Avatar
Thanks Phox. I couldn't remember how many on-off combinations.
Old 05-03-2005, 10:08 AM
Holiday's Avatar
If it's an HO engine, up to 26 is the normal boost on it.
Old 05-03-2005, 10:12 AM
xp8103's Avatar
It's not. SO.
It's 23 or so. I dont know what the margin for error is in the gauge.
Old 05-03-2005, 12:28 PM
RenegadeT's Avatar
I just connected my boost gauge. 22psi seems like my max, but its only been a few days, more testing is required
Old 05-03-2005, 04:08 PM
CORed's Avatar
My first boost gauge was about 1-2lbs high. It was an Isspro EV. It sat at about 1-2 even when off and I could make it show about 21+ at WOT.
I sent it back and the new one works correctly. So yes, it could be the gauge itself.
Steve
Old 05-03-2005, 07:15 PM
xp8103's Avatar
Ok. 0234 ECU?? IS that the same thing?
Also had a 1693 PCU pulled too. Any idea what this one is??
I have an LOF appointment on Thursday so I will have them check these codes to see what they say.
Any advanced knowledge would be supremely helpful.
thanks guys!
Old 05-03-2005, 08:07 PM
thanks guys!
Yes, P0234 is overboost.
P1693 is the code thrown in the PCM when there's a code in the ECM that the PCM can't see.
When you get it scanned you might find another code hidden in there,
or it might just be a leftover.
phox
Old 05-04-2005, 06:09 AM
CTD NUT's Avatar
I'm going to stick with my original diagnoses that the ECM is giving a 0234 DTC because of a sticky wastegate....it is still a good idea to have it scanned anyway to make sure there isn't another DTC hidden behind that annoying 1693 DTC!
Old 05-04-2005, 08:07 AM
xp8103's Avatar
Thanks guys!
I appreciate it!
Quick Reply: Boost pressure and EGT readings
