Boost Leaks
Boost Leaks
i did the boost leak test and found a big leak at the turbo elbow.. after fixing that i noticed about three pinhole leaks on 2 of the rubber boots.. is this enough of a leak to notice a big drop in power? the truck has been lacking power for a while now. i caused the elbow leak but fixed it and still seems low on power.. what you guys think
Factory boots blow up (expand) under pressure. Pin holes can cause substantial leaks.
I would not expect a severe loss in power but only a boost gauge will tell for sure.
RJ
RJ
I need to put a gauge on it.. i guess i will steal my boost guage from my boat.. where is a good place to tap in the system that wolnt be permenent?
CTD2001
13
09-06-2005 05:11 AM
