Block #53
Old 03-26-2004, 06:25 PM
DPG
DPG's Avatar
BBD, after 416,000 miles, I would have to say that the #53 stamped on your block is neither good nor bad, but irrelevant.
DeWain
Old 03-26-2004, 06:50 PM
Admin Team Leader
Lary Ellis (Top)'s Avatar
There have been a lot of problems #53 block failures, obviously not ALL of them are bad
Old 03-26-2004, 08:22 PM
Haulin_in_Dixie's Avatar
Maybe not but I got two of them, both cracked..
Old 03-26-2004, 08:36 PM
And of course everybody knows your middle name is "Lucky".
Old 03-26-2004, 08:39 PM
Trucks new name "Murphy's Law"
Old 03-26-2004, 08:51 PM
blackjack's Avatar
At 416,000 the only thing we know for sure is , that it doesn't say Powerstroke or duramax
Old 03-26-2004, 08:56 PM
AaronT's Avatar
First time I have heard of the #53 being behind the oil filter. Now I just got to go and check mine again. THANKS, THANKS ALOT.
Old 03-27-2004, 07:34 AM
spots's Avatar
Hey BBD I think you got Haulin's luck from his truck. Hopefully you haven't jinxed it now by posting 416k and 53 in the same paragraph..
Haulin is your new engine a 53 also? Yikes if it is..
Old 03-27-2004, 03:14 PM
Copenhagenjunkie's Avatar
BBD, I hope you didn't jinx yourself!
no comment from me, I am superstitious (sp?).
Knock on wood.
Old 03-27-2004, 03:37 PM
There were no casting marks on the new block, but does it matter, it has the stereotype crack on the side and is junk.
Old 03-27-2004, 03:50 PM
tool's Avatar
I can't find casting numbers on my truck anywhere.......
A few little undecipherable symbols and a B stamped near the A.C compressor bracket.
Anyone know what any of that means??
Old 03-27-2004, 03:55 PM
Crawl under the left side (drivers side) look above the oil pan rail at the front of the block. The numbers will be in that area below the injection pump. If it is a series of small numbers you are ok.
Old 03-27-2004, 05:12 PM
spots's Avatar
Any news Haulin on if Cummins is coming through with another one for ya??
Old 03-27-2004, 06:15 PM
Nothing going yet. The biggest thing going right now is a higher water bill. Takes about a gallon in 50 miles. I will get something, I have a receipt but did not purchase it from Cummins. With an open receipt for the purchase of a "new" 5.9 long block, it is a shoe in sooner or later.
Quick Reply: Block #53
