Black smoke loss of power
Old 09-17-2005 | 03:08 PM
herb's Avatar
all the sudden LOTS TOO MUCH black smoke when accelerating losss of power.
Not showing normal amount of boost when accelerating ---checked everything for tightness seems ok checked impeller on turo nice and clean turns freely no excessive play in shaft. Air filter (scotty) ok
unplugged edge and helped a lot , i think maybe the edge is just exsenchuating
the problem. any ideas
good read to file on turbo's
http://www.hotroddiesel.ca/turbocharger_faq.htm
Old 09-17-2005 | 03:12 PM
Shovelhead's Avatar
Administrator / Scooter Bum
Could you have blown off or ruptured a boot in the intake piping?
Old 09-17-2005 | 03:18 PM
herb's Avatar
I am going to go out and look again. none of the boots are off or loose and did not see anything ruptured but did not give then a good visual underneath.
this thing was running perfect until it spent the day in the shop with me yesterday installing the air ride seats.
Maybe it's just trying to get even because it still has to feel the bumps
if the turbo was bad wouldn't it show visually ?
Old 09-17-2005 | 06:37 PM
Shovelhead's Avatar
If you pull the intake hose and fire it up you should see (and hear) the turbo spinning freely.
Whan I shut mine down at idle, the turbo still spins for approx 20-30 seconds.
If yours is stopping quickly on shutdown, there could be a bearing problem.
Otherwise I suspect a boost leak somewhere.
Old 09-17-2005 | 06:54 PM
herb's Avatar
i pulled it and everything is spinning free---no strange sounds---nice and clean----no hot spots. Can't locate a leak anywhere.
Looks like i may be off to my local cummins dealer Mon morning. going to have a BD converter lock put on to accomadate the jake brake i just put on last week so guess i can kill two birds with one stone
appreachiate your input Shovelhead
Old 09-17-2005 | 06:55 PM
Scotty's Avatar
Top's Younger Twin
Intercooler?
Hoses can hold and then let go as they expand. I was amazed at how much they blow up under boost. They can leak out under the clamps too.
Scotty
Old 09-18-2005 | 01:01 AM
95ram's Avatar
Did you look at the bottom boot coming on the intercooler. It has a tendance to rub on the fender and the fender will cut a hole in it. You can't realy see it unless you pull the boot off or push it over enough to get a good look at it.
Old 09-18-2005 | 05:42 AM
herb's Avatar
is the intercooler at bottom of radiator ?
Old 09-18-2005 | 08:19 AM
Jetpilot's Avatar
Herb,
Check the hose located on the passenger side intercooler (this would be the hose located on the passenger side bottum of what looks like a radiator, the line comes from the turbo). As 95ram stated this boot sometimes rubs on the inner fender and get a hole in it. Also check all the boots very good and check for tightness, I have seen a clamp fail and look good but not really be tight. I would suspect the boots first, second would be the gaskets under the air horn or intake.....
If I can help out in any way please feel free to phone.
Doug
717-557-7060
Old 09-18-2005 | 03:26 PM
herb's Avatar
completly removed tubing and boots from the tubo to the intercooler and from the intercooler to the intake. Everything is tight and no holed or breaks
Hext ?????????????????
Old 09-18-2005 | 04:24 PM
Bart Timothy's Avatar
I had a simular problem once. It turned out to be the gasket on the intake plenum cover. 20% of it was blown out. Was the last place I'd ever thought of looking at.
RHC
08-12-2019 03:32 PM
mt250
08-22-2009 07:35 AM
cbrxxtreme
24
07-17-2008 03:30 PM
matthopp
05-22-2008 11:28 AM
WHITEY
55
11-28-2005 08:56 AM
Quick Reply: Black smoke loss of power
