bad VP44? or just map sensor..? P0236
Old 06-11-2008, 04:25 PM
mattn124's Avatar
Originally Posted by AggieJustin
Check the voltage between the Gray/Red wire and the Black/Light Blue wire from the MAP. The Gray/Red is the signal line, the Black/Light Blue is the Ground. On a '99, you should see 0.5V with the key on and engine not running.
Just went back and read this again. Looks like I might have a problem there since the reading I took was .065V with the key on
Any suggestions? Weak signal,, hope it's not a bad PCM...
Thanks
Old 06-11-2008, 04:29 PM
AggieJustin's Avatar
Well, the reading on the signal wire seems low. The TST instructions state that a '99 should read 0.5V with key on and engine off, you're reading was 0.065V.
Check your reading between the Orange wire and the Black/Light Blue. This should read 5V as the supply to the MAP sensor.
Old 06-11-2008, 04:30 PM
mattn124's Avatar
I checked the orange wire to straight ground and got 4.98 V key on
It wasn't to the other wire,, but it was ground
Old 06-11-2008, 04:42 PM
OK, that checks out.
Then I'm thinking that it's a bad MAP sensor. The only part that doesn't make sense is that I thought as boost increased, the voltage output on the sensor wire increased. I was really expecting that your MAP signal was going to read high which caused the computer to see higher than expected boost.
But maybe the MAP is screwed up and when you get boost, it jumps to a high voltage reading.
Old 06-11-2008, 04:59 PM
mattn124's Avatar
Thanks for the info and help!!
got any info for me on that loose ground wire?
Old 06-11-2008, 05:32 PM
Pardon the bad angle...the AFE box is in the way. But is this it?
billythekid4278 (11-01-2020)
Old 06-11-2008, 06:37 PM
mattn124's Avatar
YES!!! That's it exactly!!!!
THANK YOU!!!!!
I mounted it in the right spot, except I put it on the back side of the computer, I'll pull that screw out and put it in right tomorrow morning.
Heading to a somewhat local Cummins shop in St. Louis sometime tonight to get a new MAP sensor, luckily they are open till midnight.
Thanks again for the help,, if there were some kinda "rep" points or something on this board I'd sure give ya some!
Old 06-27-2008, 07:13 PM
raydocks's Avatar
hi there i just had a friend hook his computer to my truck after installed an airdog setup and he was showing me the map sensor on the rightside of the engine ? not the small black box i see on your engine but it screws in to the block like a temp.sensor. how about letting me know if this is correct.
Old 06-30-2008, 09:55 AM
The MAP sensor is on the driver's side of the engine, just behind the fuel filter housing.
The pictures I had included earlier were showing a ground location at the PCM.
Old 06-09-2015, 12:22 PM
12valvin's Avatar
Hey guys what was the outcome on this problem? I'm having very similar issues.
Thanks
I have an 01 2500 auto
scottboy69358
07-04-2013 02:05 AM
Moobesor
02-23-2008 09:57 AM
kkyle69
07-07-2007 12:33 PM
Gene007
0
02-26-2006 04:31 PM
Booost Almighty
01-01-2006 01:41 PM
Quick Reply: bad VP44? or just map sensor..? P0236
