Axle leaking oil
Axle leaking oil
my drivers side axle is leaking out oil. how hard is it to replace the seal myself? and does anybody have any links to a good writeup?
front axle...i'm figuring i need to take out the driver side axle. if i take out the diff, can i just shove it back in afterwards without needing to adjust anything?
Front axle seals should be swapped on both sides.
You will need to remove the differential. When I did mine I could pull it out by hand. The manual says that you may need a spreader.
Just my 2c
AlpineRAM
Just my 2c
AlpineRAM
lilsuzuki4x4
09-01-2011 01:50 AM
KKoteles
11-09-2008 05:48 PM
jon05ctd
21
08-17-2006 02:26 PM
