Auto tranny questions--upgrades??
Just bought a 2002 Ram (my first diesel) and noticed the transmission acting strangely. Overall it shifts good and no signs of slipping, but when slowing down the transmission downshifts into first pretty hard and makes a slight clunking noise...any idea what this is?
Also what can I do to help the tranny live longer besides adding deeper pan and large cooler???
Aftermarket valve body?
From: My head lays down in Murrieta, but the day light hours are spent in San Diego, Ca.
Check all the mounting bolts and the cross member bolts.
As for the other, yeah, a built valve body would help big time. Another member here on DTR (I think his name is Blackdodge, maybe) was running a DTT valve body and was pushing around 500 hp. I think. It's been awhile since I read it.
Check your u-joints also. If quite a few miles , servic - filter, fluid - band adjustment. The bands being adjusted properly affect the shift timing.
I had my factory torque converter start slipping so replaced it with a DTT single disk and SunCoast valve body. Pulled the check ball from the heat exchanger per Sun coast. Rest of the trans is stock and shifts good and solid now.
lews930
03-07-2007 07:33 PM
ezdemon72
14
07-29-2005 11:05 AM
j
19
09-12-2003 12:28 PM
MrDiesel
11-29-2002 10:27 PM
