AUTO oil filter change WONT upshift NOW!HELP
Old 07-01-2008, 01:16 PM
Dodgezilla's Avatar
If it was working perfectly fine before you did this then I would bet that you have knocked something loose or somehow messed up the linkage. My bet would be that your linkage is not adjusted properly...
Old 07-01-2008, 04:07 PM
smokinram99's Avatar
my tranny isn't perfect, when cold shift hard from 2nd to 3rd or won't shift up for the first 5, 10 miles. I have pulled off the pan, change filter, rebolt pan..added oil. when I checked 2nd time I took a look at the sensors, the one on the passenger side, front trans(to engine) is a bit loose, if I take my fingers on it, it moves a bit(isn't firm), but don't know what sensor is that or if a bit loose is ok....
how can I check the linkage??
Old 07-03-2008, 01:14 PM
How to adjust linkage??
Old 07-07-2008, 02:09 PM
chenged vout the Speed Sensor on the Driver side of the tranny(external) on the trans tail...a little better when in temperature..
waiting for the governor solenoid and the other external sensor..
I have also re-changed the ATF, from Royal Purple fully synt to a semi synt ATF +3, but nothing changed.
Old 07-12-2008, 06:11 PM
next week I'll try replacing the Pressure Sensor in the pan and cleaning the 2-3 gear SHIFT VALVE. following ATSG manual
Is this a good job?? anyone done it??
rob
Old 07-16-2008, 03:33 PM
I've replaced the PRESSURE SENSOR in the pan but NO change...I still have my problem.. tranny wont shift into 3rd untill I drive for about 10 miles...then shift.... anyone can help me??
rob
smokinram99
08-12-2008 05:38 PM
smokinram99
05-04-2008 05:59 AM
Chief Dodge
02-01-2005 05:39 PM
jlells01
11-23-2004 03:21 PM
reaton
07-11-2003 04:27 PM
Quick Reply: AUTO oil filter change WONT upshift NOW!HELP
