ATF+4, is it synthetic?
is ATF+4 synthetic? i talked to a tranny builder about changing the fluid and he said to use ATF+4 non-synthetic. i looked at every parts store in town and no ATF+4 non-synthetic to be found. i thought ATF+4 was synthetic.
thanks dieselfan
thanks dieselfan
To my knowledge it is not a true Synthetic.
just filled my tranny up with valvoline ATF +4 all sythentic.
consider partially dropping your valve body to drain another 4 quarts out of your tranny for a more complete flush.
i plan on adding a shift kit, so i will taking the VB out completely.
i was gonna get 15 qts to be safe.
thanks dieselfan
I posted a bargain alert of $3.49 quart for valvoline ATF 4+ from our local NAPA. vs $6 for mobil one synthetic
I got another 4 quarts out by partially dropping valve body. took 7.5 quarts to refill. some ended up on the ground due to no drain plug.
installed a drainplug from Napa. no mess next time. wish I had been able to complete change out fluids. but 8 quarts is better than 4.
new +4 fluid is already getting dirtied up by old residual fluid. but you would not believe the improvements in shifting by simply changing fluid.
Pig
23
06-04-2010 01:01 PM
dieselfan
08-05-2006 10:44 PM
Pig
03-13-2006 09:12 PM
