APPS Voltage
Old 04-30-2007 | 12:00 PM
Wilber1's Avatar
APPS Voltage
I had a check engine light with 0122 code. Did an APPS reset and they disappeared for a month but are now back. Truck runs fine. Checked voltage at the PCM and it was .538. Tag on APPS says .562. Should I be getting a code with this difference? Can it be adjusted out? The screws are so tight I can't budge them with a torx and would like a little input before I try vice grips. Is changing an APPS just a straight nut and bolt operation? How much should I expect to pay for a new one and are they a dealer only item?
Thanks for any advice.
Old 04-30-2007 | 12:24 PM
RowJ's Avatar
Mine was out more than .024 and I never got a code. You can adjust it all out with a little trial & error.
Can't help you on changing the APPS...never done it.
RJ
imbodie
21
01-08-2024 08:49 AM
wadecool
03-25-2007 02:01 PM
Ocmechanx
02-15-2007 08:44 PM
Diesel-Dan
16
02-13-2007 08:15 AM
DuaneWKKC
10-26-2006 06:59 AM
Quick Reply: APPS Voltage
