APPS removal and testing
Old 02-04-2003 | 10:33 PM
Scubasteve's Avatar
???<br><br>This is on a 2001 with an automatic<br><br><br>I think the APPS on my truck has a dead spot in it which is causing my truck to return to idle while driving . this always seems to happen at the same throttle position. I was wondering what the specs are on this unit and if its that hard to remove to test. I am guessing that it works the same way the TPS did on the 12 valvers but I dont want to get into it without a bit of knowledge on the unit. The TPS's were easy to test but i havent had this unit off yet.<br><br><br>Any help would be greatly appreciated<br><br><br><br>Jason
Old 02-05-2003 | 08:57 PM
Scubasteve's Avatar
Re:APPS removal and testing
Thanks for the offer man, that is very kewl!! ;D<br><br>I am going to take the sucker off when i get a chance and test it out to see if thats what causing the problems that I have been having first before I replace anything. I am pretty sure if there is a dead spot it will show up with a simple multi meter ohms test. I will let everyone know what I find once i get the time to take it apart.<br><br><br>Jason
Old 02-06-2003 | 11:56 PM
Kennys's Avatar
Had one go out on mine and it set code in the computer. Don't know any way to check them, mine didn't act up all the time, but I kept thinking that it wasn't going to come back on when I was far from home. They are expensive and you can't get them from Cummins. Kenny N4YYX
trik396
06-01-2008 08:04 PM
DuaneWKKC
04-08-2008 06:42 PM
