APPS Code and ole 1693
I threw an APPS low voltage code and cleared it by doing the reset. Now I still have the 1693 code. Does the APPS code automatically throw the 1693 code or do I have other problems? Will disconnecting the batteries clear the 1693 code? Truck is running fine now after the reset.
you should be able to clear the 1693 with a snap-on scanner.
did you adjust your apps? It needs to read at leat .49 volts or it will just throw that code again and make your truck run badly
I haven't checked the voltage. I guess if it comes back I will probably have to replace it. Will a new one solve this problem or is there another problem that is causing the low voltage?
darrenG
07-10-2006 04:59 PM
jt_gladstone
08-09-2005 11:24 AM
