anyone heard of mixing used transmission fluid with diesel
Have you heard of filtering used tranny fluid and mixing with diesel to save money on fuel?
I read lots on here and you DON'T want to burn tranny fluid. Too many cleaning agents, etc. Especially on our VP's that are running on borrowed time anyways....
Good used motor oil that you know where it came from, maybe, if its well filtered, etc. But the bit you'd save on fuel, versus a new injection pump and a tow job, you'd have to crunch the numbers and see if the risk is worth it to you.
The risk is not for me...
Just my .02
Just my .02
I don't see any problem using it other than the color. If you get the tank dipped by the authorities and they see the red color it may cost you $10,000.
My 95-12valve loved it. A quart in the tank and it would get 2-3 MPG better each and every time.
This 02 doesn't do any better, so I don't put anything red in it.
I think from reading many posts, that Tranny fluid is not meant to burn in a diesel, certainly not not Gen2 or later, maybe not even Gen 1. 2 cycle oil seems to be the recommended(Itis designed to burn) and, perhaps, Power Servce , Lucas, or other similar additive.
I would not use any automatic transmission fluid in any diesel motor. Tranny fluid does not completely burn. Try to burn some on a steel plate, you just end up with a black almost tar-like mess. I wouldn't want to see that stuff stuck on my valves, pistons, and injectors etc.
missouriman
11-12-2010 06:53 AM
aborgardt
06-06-2009 04:18 PM
redpoint5
36
02-08-2007 05:07 AM
