Amsoil switch=No more blow-by!
Old 02-11-2003 | 04:47 PM
DEZLPWR's Avatar
Just switched from Mobil Delvac1 5w-40 synthetic to Amsoil synthetic &amp; noticed that I now have NO blow-by oil coming out of the puke tube.....This is even after a hard run, where before with the Delvac, I would often have a couple of drops! Don't get me wrong, I am not complaining, but I have a hard time believing that the switch to Amsoil 15w-40 HDD is doing it. Anyone wanna comment on this interesting phenomenon? I thought as engines get older, you get MORE oil puking out of the tube, not less...<br><br>FWIW, I have 93,000mi on the engine, 23K of which have been heavily bombed....
Old 02-11-2003 | 08:53 PM
jerryb's Avatar
Re:Amsoil switch=No more blow-by!
thats because of viscocity not amzoil, even if you used 15W40 penzoil it would have less blow by than 5w30 amzoil or mobil 1 or whatever.
Old 02-12-2003 | 01:30 AM
atoughram's Avatar
I typically go through maybe a half a quart between oil changes, and most of that is lubing the dront differential exterior.... (Through the draft tube) Delo 15-40, 78,000 miles and 45,000 bombed.
Old 02-12-2003 | 11:27 PM
BigK's Avatar
C'mon, Steve, enough w/the Amsoil hype. <br><br>I'd never use that stuff <br><br>Least your change was cleaner than my neighbor w/the F**d. Took a bag or two of absorbent to clean the floor after he dropped, and then threw the filter into the drain pan. Splash! 'Course, he still uses F--M products on occasion , along with C*****l. To each their own.<br><br>He brings refreshments to fill the fridge, so we let him come around. The entertainment is almost as good as finding someone in the bathtub
Old 02-13-2003 | 04:04 AM
Dieseldude4x4's Avatar
AMSOIL, what's that?
Old 02-14-2003 | 05:34 PM
AlpineRAM's Avatar
I have switched from Castrol GTX to Valvoline Premium Blue- very good move. Less oil consumption- about a quart on 6000 miles before, now virtually nothing, less rattling and knocking when cold. <br>And a whole lot cheaper! <br><br>AlpineRAM
Old 02-14-2003 | 09:40 PM
Fishcop's Avatar
French Fry oil?...........I'm sure old Al Amatuzio would disagree ;D
bgflatbed
08-03-2010 02:20 PM
Spooler
28
12-26-2009 11:16 AM
czkid
10-18-2007 08:38 PM
Mexstan
04-09-2003 11:14 PM
Quick Reply: Amsoil switch=No more blow-by!
