Air not cold - clutch cycling every 3 seconds at idle - Whats wrong?
As the title says - clutch for the air is cycling (on/off) every 3 seconds at idle and the vent temperature will vary with cold/cool flow of air. Any sugestions?
Your system is probably low on R134. It has enough for the system to cycle but it does not take much for the compressor to suck the low side down to 20psi if the system is is undercharged causing it to cycle constantly. A good rule of thumb is your compressor should never cycle more than 8 times in a minute.
Mine is not as cool as it used to be. It always did take a long time to get really cold.
It checked about 15-20 psi then went to 50-60 psi between cycles. I hooked up a recharge kit and it now is 20-30 then 45-50 at 85+ ambient. It cycles about 6 times a minute. It only took about 1/4 of the can.
I checked all the positions and it works ok. I don't think there is anything wrong in the controls. Both heat and cold work ok. I don't get a lot of leaves collecting on the hood either so I think it is clean inside.
It eventually cools but it takes a good 1/2 hour to cool off when it's been sitting in the sun. black truck.
bluecyclone
04-14-2011 08:27 PM
dieselfuelonly
07-19-2010 04:22 PM
Coaldigger
09-24-2008 03:05 PM
tyssniffen
01-03-2007 08:10 AM
