Air dog 100 and stock pump delete???
Ordered a air dog 100 and a big line kit from vulcan and was wondering do you delete/ take off stock lift pump? If so do they make a block off plate or will I have to fab. something up? With 100 I don't need a draw straw,but I noticed that they are now making a replacement sender with bigger lines and a return line,new float etc. my fuel guage is off anyways so I might go this route if needed.Thanks, Nate
My Air Dog 100 came with the big linesalready,,,,, so I don't know, maybe they sell just the pump?
On my install, I just unbolted my OE pump from the mounting plate that covers the hole your talking about,,, I also took off my fuel filter, since the Airdog has it's own.
I would install a DrawStraw with EVERY fuel system!!
Just too many restrictions to not do it right.
You can remove the stock fuel pump. The bracket covers up a hole in the block. You can remove it, cut it down into a block off plate if you prefer.
Dave
Dave
new module VS drawstraw from vulcan
O.K so does the "new" module they are selling act as a drawstraw? My fuel gauge is not working properly so I was going to go that route........ but if drawstraw is better....... my 100 comes with big line kit..... I thought I would need big line kit from stock filter to VP and was not sure what all comes with 100. Is there fittings and Enough hose to delete the stock filter and get to theV.P.?
What module who is selling?
If you are referring to the Pureflow draw tube kit, it's less effective for more money. The complete modules do not take the place of a DrawStraw and Vulcan is even modifying new modules with a DrawStraw V already installed.
Dave
Dave
it already comes with big lines unless you plan on going as big as PVC plumbing, didnt they tell you that when you ordered it? and they are a pain in the neck to get on up by the VP
Not pcv....lol I ordered on line so no one to talk to......... so they give you enough hose I take it to go from the tank to pump and pump to VP and all fittings needed, If I Deleted stock filter. Guess I'll be returning the big line kit that goes from filter(stock )to VP that I ordered and get a drawstraw.Have to go to Dodge Directly for sender/float to fix my gauge issue.
http://www.vulcanperformance.com/Dra...w-p/jlfmds.htm but this states for jeep liberty..... are they doing them for our trucks as well cause like I said my gauge if foobarred $50 for drawstraw and another $50 to fix gauge or $199 for whole assy.......
Dave
Dave
I had line left over i think about a foot or so and its some pretty fat line too, my pressure stays at 18-21 psi idle and when i mash it it doesnt drop below 16
so, I called Vulcan yesterday... they were confuised when they saw that I ordered that big ling kit so I will be returning that..... (nice people BTW) ordered a drawstraw from them but it will not get here quick enough cause I've got a 500 mile trip planned this weekend haul'in load so I want to get it installed before I go..... Can I just tap into fact lines for now.......until straw gets here? the air dog 100 I assume comes with a straw but you must have to drill tank? thanks, Nate
trailinone
16
06-19-2009 04:28 PM
Hvytrkmech
25
02-28-2009 08:52 AM
53 willys
38
11-06-2008 11:18 AM
Super Dave
14
01-16-2008 09:26 PM
