ABS light on Brake light on...Speedo weird!
Ok lights went on yesturday, not sure why. But also now the speedo is acting weird also. Registers then dosent. Anything above 60 and its fine.
Any ideas where to look?
First pull that speed sensor out and clean it off once. It's probably got the metal parts all covered in metal particles. They are magnetic and collect annd the stuff in the rearend. Clean it off and put it back in. Clear the abs light and take it for a drive. If that fixes it. Then drain and refill the rear diff to get the rest of the shavings and crud out. If it's cracked and oil has gotten into the plastic housing, then go get a new one.
Disconnect the batteries for about 30 min. Turn the key on after they are disconnected to drain all diodes, etc.
Also, I found out on here the other day that you can disconnect the red cable from the battery to the fuse box under the hood and do the same thing. It's a lot easier the disconnecting the batteries.
Joey-D
12-12-2011 12:52 PM
mr T
02-24-2007 06:42 AM
Rocksville
08-21-2005 09:58 AM
