ABS/Brake Lights cycling randomly
Well I've been fighting my abs/brake lights now for the last 16k miles. I've replaced the rear speed sensor and both front hub sensors. They just randomly turn themselves on and off. Recently they've been doing it after a full throttle run or if the road is bumpy which leads me to think a loose connection but I've checked everything and nothing is loose.
I burned my posi up which has been setting my lights off for a while. The metal shavings are messing with my speed sensor. If the rear fluid is clean and the sensors are new i dont know where to look but, the slightest metal in the rear will do it.
If you're breaking the rear wheels loose on the rough roads or on your full throttle runs, the speed differential between the rear and front wheel speed inputs can trip the ABS/brake light(s).
Rusty
Rusty
BuckyKatt
02-08-2013 01:12 PM
2006Mega
01-15-2010 08:54 AM
quadstar
11-20-2009 05:23 PM
polaris800sp
11-13-2008 05:35 PM
