ABS and Brake LIGHT SCANNER
Hi to all,
I have a 2000 Dodge Ram 3500 and have been looking to buy a scanner/reader to read the ABS codes. Most of the ones that I have looked won't read the ABS codes. Does anyone know of one that will read the ABS codes on a 2000 Ram??
I don't know about a code reader but you can check each of your abs sensors with a ohm meter usually that is what sets of the abs light which will turn on the brake light also. Brake light fuse will also set it off.
fitzydog
21
10-11-2017 12:09 PM
Joey-D
12-12-2011 12:52 PM
mr T
02-24-2007 06:42 AM
