99 dodge Not starting!
Old 07-18-2017 | 12:27 PM
99dodger's Avatar
So on Saturday truck was idling when warming up weird low rpm to regular rpm. It had a few times where it didn't start right Away but once I got it going on the road it was working fine. It has a fass pump that was put on 2-3 years ago. Haven't checked the pressure of it or changed fuel filter since I owned it(2years)
Saturday night I parked it now it will turn over just clearly not getting any fuel at all I can hear lift pump come on just not starting! Give me som suggestions on what may be the problem!
Old 07-19-2017 | 12:03 PM
VADSLRAM's Avatar
Does the lift pump sound normal?
If you have a leak in the suction line you could be pulling air in and that would prevent it from starting.
Old 07-19-2017 | 11:46 PM
Puke's Avatar
The lift pump making noise and running does not necessarily eliminate the lift pump as a possible problem.
Old 08-06-2017 | 06:42 PM
brophyn70's Avatar
Check the fuel pump relay?
Old 08-06-2017 | 09:57 PM
SIXSLUG's Avatar
How is it clearly not getting any fuel?
I'd scan it and see what codes relating to the vp come up.....after all the simple stuff, like ensuring there is fuel in the tank, the filter is clear, the batteries are fully charged....
patti
11-01-2012 05:20 AM
fourthandgoal
88
12-27-2011 06:39 AM
RED99CTD
04-20-2011 09:08 AM
abc4yew
03-16-2007 12:55 AM
