6 speed oil change
6 speed oil change
I was going to change my gear oil in my 6 speed trans.
Now I see in my owners manual it says the oil is good
for the life of the tranny.I don't believe that, but I bought
the truck used with 42,000 miles and it now has 52,000
miles. I don't drive it hard and only tow 6500# about
once a month. Do I need to change the oil yet or should I
wait. Not having any troubles yet ,was just going to do
preventative maintenance.
What oil are you using?
I run redline MTL in my 6 spd because I was getting notchy shifts and it cleared that up for me. It also helps my 6 spd shifting in weather below 20*F.
If you bought "stock" fluid, then go ahead and change it.
If you run something else, like MTL, then DC can void your transmission warranty.
Jason
Jason
doubledodge2003
02-21-2005 10:18 AM
Sonny
02-16-2004 12:47 AM
