53 block?
53 block?
Hey Im sure this topic has been discussed before but what is the concern with a 53 block, would my 1998.5 have that number of block? If so what could happen and is there anyway to prevent a problem with them?
i got one and am not worried.....look on drivers side just below injection pump where oil pan meets block, u will see a big 53 stamped into the block....a while back i switched to rotella elc coolant for diesels, might make a difference as far as heading back corrosion but who knows....most block cracking has occured on the 53 blocks for those who tow heavily and on bus applications.....anything u can do, cross your fingers.
My completely stock 99 quad cab had a cracked #53 block. A motor from a wrecked truck fixed the problem. If you have a #53 and it is not cracked a bit of preventive maintence would be to use evanscool in it.
I've seen the 53 casting problem mentioned many times, but mostly concerning modifications.
Today I noticed some drips under the truck. I ran it, did not see any leaks though I looked everywhere. Revved up the truck and voila there are some drips coming of of the stabilizer bar, and behind the pulleys. I'm assuming its a water pump... story for another thread.
What's really interesting is that I found all sorts of threads on the notorious 53 casting. I went out to identify my block and I got a 58L or 581 or something to that effect. There was another post where someone reported a 58 cast number showing under the LP by the pan... Could this be accurate? There are 3 numbers, and the first 2 appear pretty clear "58".
Any one else out there with a 58 cast number?
2001.5 24v Ram Auto...
Stock 53
My 98.5 53 cracked @ 17,500. Dealer replaced with shortblock and liftpump went the next day. Completely stock at the time. Since replacement installed EZ ,DD2's and DTT. New 53 is thriving!!!!! So Far.
Mine went at 122,000 miles,,,,, I knew what I had. Just a luck of the draw. I got lucky and found a long block from a fire fer $850 delivered! Swapped my head and Inj pump. Runs great! Did the work myself with the help of my son. Total cost: $1400. Time spent with son: PRICELESS!
24Vford
01-02-2007 11:14 AM
1320
05-17-2003 03:28 PM
