47RE not shifting out of first.................
I've got a friend with a '99 his 47RE wil not shift out of 1st gear without lifting off the peddle, once you lift out it seems to shift through the gears just fine.
A year ago he had a similar problem and it was a speed sensor in the trans., he threw a new one in it today and it is still down the same thing.
The trans., as far as the paper work says, was built by BD. It has one of there valve bodies in it.
We serviced it and adjusted the bands after the speed senor was changed and it still didn't make a change.
Any thoughts or idea would be appreciated.
Personally I would drop the pan and check the kickdown band servo and make sure everything is in it's proper place. I run into a few of these with that exact issue and find the kickdown band strut laying on top of the valve body due to it being too loose. I know you say you "serviced" the trans, but the kickdown band is adjusted externally so I'm just curious if you noted if everything was in place.
Hmm isn't that funny, mine just started doing this this morning on the way home from a friends place Pulled out of the driveway, shifted into second, then right back down to 1st and stayed there until i let off the throttle. Tranny didn't even feel right driving away at 5 km/h...so I guess I will have to get it looked at. Maybe its time to save up for a new TQ and Valve body to put on as well
Oh and is it still alright to drive it until i get it fixed?...not sure when that will be.
typz2slo
10-25-2011 09:30 AM
patg
09-23-2010 12:30 AM
DodgenIt
02-20-2008 01:59 AM
