4 wheel or 2 wheel ABS?
Ok guys, went to get some brake parts at the lovely auto store and was asked if i had 4 wheel or 2 wheel ABS...and i really have no idea....I need the hose that goes from the caliper to the hard line and there are two diffrent ones listed.
Another thing thats probably a bigger problem is that i don't think my ABS is working at all but i don't get an codes nor does the ABS light come on saying i have a problem...??? Is there some way to disable the ABS without it knowing????
Stew
Stew
There are better ways to check this but without a book probably the easiest way to check is look for a wire going to the front hub to a speed sensor. No wire = 2 wheel ABS or "Rear wheel ABS" If you ABS is disarmed, the speedometer will not work correctly.
fitzydog
21
10-11-2017 12:09 PM
sssmaly
07-13-2007 12:57 PM
mr T
02-24-2007 06:42 AM
