3 Cylinder high idle?
#47
IMHO, better for your engine to plug your truck in, when it's below 40* and never have to use this high idle feature.
If you can't plug in, getting the high idle from a Smarty would be a good second choice.
As for paying a dealer for it.... A stick between the seat and the throttle, and a winter front (blocking some air flow) will do the job!
These things won't give you the 3 cylinder high idle ..... but after hearing it, you may feel like me, and not really want it
RJ
RJ
#48
I love the description (..... the motor sound will change slightly...) haha You can hear the motor 1/2 a block away upwind in a 40 mph gale.
Cummins should seriously think about a 3 cyl 2 liter (5.9 minus 3 cyl). Put it in a half ton dually and I'd have to consider trading the big truck just for the cool sound. .
Surprising the exhaust note is a bit quieter both high idle and 3 cyl. It does have a bit stronger smell however...not that that's bad.
#49
Thanks for the info. I talked to the local dealer today I told him the tsb # he said he had never heard of it and he would have to look into it to see if it would work on my truck. So I can tell him it will. thanks
#50
RJ
RJ
#51
I agree that plugging in is best but when you can't, I think the idle up and 3 cyl is good. It sure doesn't take long for the motor to warm up. I let it 3 cyl for about 2-3 minutes then kick the pedal and take off. Within about 10 minutes I'm up to operating temp. It can take 1/2 hour otherwise. Especially around town.
My neighbors don't like my generator running in the morning so I'm stuck I guess.
#54
21alpha:
I live down in Castle Rock and would be willing to set you up with a smarty load/unload. PM me and we can surely work out a time to get together. Should only take a few minutes.
#55
#60
RJ
RJ
Does any of you guys use an exaust brake for quicker warm-up? Works Awsome! With high idle and the ext. brake on @20º, I'm at 160º in a little over 5mins with a stone cold engine. Takes a least 10min plugged in to reach 160º even with the ext brake on and engine start temp around 75º.
This combo works great and now all I need is remote start, and I've got it made. All automatic. When the brake kicks off its time to head out, all warmed up. If intrested, I can do a diagram of the temp control for warm up with an ext. brake. Let me know, its simple.
