3 Cylinder high idle?
Hi,
I am a little confused, do the 2000's have a 3 cyl idle? Last few starts have been cold, about 5*F, had no power to plug in last time. Awful noises from power steering and maybe brake booster.
Anyway, it will idle at about 900rpm, that's not the high idle is it?
And will I know if it's on 3cyl?
Thanks!
Thanks!
3 cyl idle TSB 18-019-1
It is "3 cylinder enable"
There is a HI idle feature, I think it is on 3rd gen where using the cruse control it is possible to increase the idle speed.
This is from memory from a guy that hides his own easter eggs.
Thanks a lot! So as I understand it, the truck is capable of doing it, only I need to get it "unlocked" by a dealer or someone with a Smarty?
Anyone close to Golden, CO with a Smarty? There would be food or beverage payment!
Check this thread to maybe find a member near you:
https://www.dieseltruckresource.com/...ad.php?t=80812
Here link to TSB http://dodgeram.info/tsb/2001/18-019-01.htm
Oh and incase its not working until its much colder than it should try cleaning your IAT:
http://dodgeram.org/tech/dsl/sensors/IAT/clean.htm
Don't mean to hijack this, the high idle/3 cyl. will work with a standard tranny as long as the ebrake is on? and you don't have to turn the cruise on it will just rev itself up? the dealership told me I'd need a $400 switch on the clutch to make it work after they upload the info is this right? thanks- Chris
It's cool Cheney, that's sort of what I was asking, thought I heard the manuals need more than a software change. Anyone had it done at a dealer and know the price?
