3 cyl high idle?
3 cyl high idle?
So the other day I went out to start my truck, and i was a idiot the night before and didn't plug the truck in. Needless to say it was -25 degrees farenheit, and i had to go to work. So i started it and it all sounded good, and it went into its normal high idle (elevated to 1200 rpm), and then without it changing rpms, it sounded like it got rougher in running, almost like it dropped a few cylinders. I then proceded to tap on the brakes, and it instantaniously went back to normal, and then not even 45 seconds later it went back to doing that same thing. I bought this truck about a year ago from a dealership that said it had never been chipped, and I had a new ECM put in it not even three months ago. Does chrysler have a flash where the engine at a certain temperature will go into a three cylinder high idle?
it's normal if you have a new ECM...read this TSB: http://dodgeram.info/tsb/2001/18-019-01.htm
it's a feature that reduce warm up time..
rob
rob
the_fox_man4
02-11-2007 09:36 AM
GR40RCapri
16
01-18-2007 02:07 PM
getblown5.9
12-20-2006 10:02 AM
