24V stumble finally solved...
... on my truck at least. I plugged the MAP back into the factory wiring harness, leaving the MAP connections on my Comp hanging there, and I also replaced the orificed boost elbow with the stocker, so that boost would be limited to the stock 20 psi or so.
The dreaded stumble was gone! ;D
Of course without sensing any boost though, the Comp did nothing that I could tell. Off & 5/5 felt exactly the same... no power difference. So I plugged the Map back into the comp and the Comp back into the factory Map connection, but left the factory boost elbow in cuz I was mid roadtest. Still no stumble, and 34 psi boost ;D
Then I tried removing the boost elbow completely, and plugged the outlet. Still no stumble, 44 psi boost and quick throttle response.
Looking at the orificed boost elbow tonight with a flashlight, it looks like either a little piece of teflon or a piece of brass thread is partially blocking the tiny passageway : :
Tomorrow I will clean it out and reinstall it and see if the stumble is still gone, and also to keep the boost at a reasonable 38 or so.
Re:24V stumble finally solved...
Well now that your stumble is fixed you are going to have to add the ;DTWINS ;D so you can make 60 psi of Boost! That is if you want to keep up to that Chebby of mine . Glad to hear that it is finnaly running good!
[quote author=kingofdodge7131 link=board=4;threadid=11664;start=0#110981 date=1046659699]<br>Id like ot see a pic of this chevy haha<br>[/quote]<br><br>I've driven it.<br><br>Try this:
Yep, that's a picture of a chevy, I am pretty sure -although I have not seen very many. <br><br>WE KNOW THAT"S A CHEVY----- WHAT"S UNDER THE HOOD!!!!<br>
[quote author=dodgeman01 link=board=4;threadid=11664;start=0#111158 date=1046708312]<br>I like how it says DODGE really big on the valve cover. ;D<br>DM01<br>[/quote]<br><br>TOO FUNNY!!! <br>
[quote author=dodgeman01 link=board=4;threadid=11664;start=0#111158 date=1046708312]<br>I like how it says DODGE really big on the valve cover. ;D<br>DM01<br>[/quote]<br><br>You were expecting 'CAT' maybe?? :
Hey don't get me wrong, I would have bought the Dodge CTD except when my 6.5 puked it guts I had a truck that needed a engine anyhow. The cost for the ISB versus another 6.5 was almost identical. So I figured that I would put the best diesel engine in the truck!<br><br>Love that Cummins!<br>
king5335
26
01-17-2010 08:57 PM
buddy26
16
01-14-2009 08:29 PM
Lost Texan
04-02-2008 11:22 PM
Timinva
12-16-2002 06:05 AM
