24v idle time
Old 02-21-2003 | 10:35 PM
zoomie72's Avatar
24v idle time
please bear with me as i have a lot of ?'s about ctd's.what is the reason for not letting your truck idle for long periods of time,and what is the max you let idle?we want to keep the truck in good condition so any would be appreciated.thanks zoomie 8)
Old 02-21-2003 | 11:23 PM
Rob Thomas's Avatar
Re:24v idle time
The reason is "cylinder washdown", which is caused from lack of combustion chamber heat. You'll find many different opinons on idle time, I don't let mine idle more than 15-20 minutes.
Later, Rob
EDIT: Welcome to the site, and nice choice in transmissions! ;D
Old 02-22-2003 | 09:44 AM
roadrat's Avatar
Re:24v idle time
I am new at this also, had my truck for a whole month now ;D as i understand it you can let it idle all day as long as the rpm's are brought up to 1200 to 1500. psdieselproducts.com has a plug&amp;play unit that will do this for around 200.00 buckeroos<br><br> rob
Old 02-23-2003 | 12:41 PM
RED121572's Avatar
Re:24v idle time
<br> I start mine on cold mornings, I let it idle for two minutes. ( Two or three minutes longer if I forget to plug it in), and then go.<br><br>NEVER, EVER let you motor idle for long periods. I made the mistake of doing that in the begining. You risk contaminating your oil and clogging up the combustion chamber with soot. <br><br> Those of you letting your beast idle for long periods of time...do you see your oil getting black before it should?
Old 02-23-2003 | 06:49 PM
Cold Diesel's Avatar
Re:24v idle time
I wouldn't let it idle for much more than 10 mins or so without an e-brake or a high idler. However with my high idler I often let it run for 2 or 3 days without turning it off at all as I am often without a plug in and the temps can be -25*F and below. Also my oil is black right after it goes in Red 121572. I believe its always been that way since I've had it and I got it new.
banks twinram
05-18-2010 08:10 PM
king5335
26
01-17-2010 07:57 PM
Smokin'02
02-09-2009 08:43 PM
buddy26
16
01-14-2009 07:29 PM
swamper303
01-28-2004 04:25 PM
Quick Reply: 24v idle time
