View Poll Results: Best option for dealing with the stock 2nd gen lift pump?
FASS
32
40.00%
Airdog
20
25.00%
Frame rail relocation of Carter lift pump
11.25%
13.75%
Walbro
10.00%
Voters: 80. You may not vote on this poll
24V Fuel System: Airdog, FASS, or Relocate Stock Lift Pump?
Old 02-20-2008, 06:37 AM
scout98's Avatar
I throw my hat in for Airdog I have had mine for several months now the best upgrade I have done to my truck so far.
Old 02-20-2008, 07:17 AM
jrs_dodge_diesel's Avatar
Originally Posted by jentas
Sorry, I should have included the Walbro and Glacier options--or at least lumped that option together as "frame rail relocation of a lift pump". I guess I overlooked them because I just hadn't really been considering the Walbro or Glacier kit route when I can get an FASS or Airdog for a few more dollars.
Does anyone know if you can edit a poll?
Walbro added to the poll.
Old 02-20-2008, 09:13 AM
jentas's Avatar
Originally Posted by sheriffav8r
I paid $119 on e-bay for a Walbro 392 with the install kit. That, plus some plumbing parts (Swagelok pressure relief valve, Jegs Y-Block for fuel return, etc.) gives me a great set-up for under $250. That's $170 less than GDP. I'm putting it on this week. My frame mounted Carter is a POS and puts out a whopping 10psi on the frame rail. Figure a 3-5 psi drop for distance and filter and you're getting nothing at the VP-44. I think that's why they put the stock pump at the engine, because it's so anemic....
This sounds like a pretty decent option you're going with--I had only seen the Glacier Diesel kit that is running over $400. Did you already add a big line kit to put the carter on the frame or are you leaving some of the original hose and fittings? $250 is sounding pretty good for a solid setup.
Also, I see you're running the commander. Have you calibrated you're unit to the actual fuel pressure with a manual gauge? I've never really been sure what my fuel pressure is with that commander because of the adjustment feature--you can adjust it so that it shows anywhere from about 9-16 psi at idle and I've always wanted to check what I'm really getting from the carter. I always leave it set around 14-15 psi at idle and it will pull down to maybe 12 psi under hard acceleration on my stock setup, but I don't even know if these are the real numbers.
Old 02-20-2008, 09:45 AM
53 willys's Avatar
I say anyone but the Carter
but I voted airdog...small and quiet
Old 02-20-2008, 10:24 AM
mcoleman's Avatar
I've been running an Airdog for the last 110,000 miles or so. I'd buy another in a heartbeat.
Old 02-23-2008, 02:51 PM
MVIEIRA's Avatar
My vote is for the AirDog also, I've had mine for a little over 2 years and it has worked flawlessly. It's very quite and the compact size allows it to be mounted behind my transfer case and protected by the skid plate. I also like the 3 micron filtration.
Regards, Mike
Old 02-23-2008, 03:29 PM
Puke's Avatar
Why is it I bought a $29. electric fuel pump and put on my old 1 ton gasser in 1984..and it is still going?????? And we can't seem to find something for under a zillion dollars (and I still think in 25 years it may not be going anymore???)
Did I just get a freak good pump at pep boys?? Do I need to pull it off and have it bronzed?
Old 02-23-2008, 03:38 PM
J Lent's Avatar
I had a Fass & now have a Airdog. The Fass was too noisy, Airdog is smooth & quiet. Fass would drop pressure to 10psi on a hard run, Airdog doesn't go below 14psi. The Airdog is $450....well worth every penny.
Old 02-23-2008, 04:43 PM
1BAD4X4's Avatar
Is that a complete system or just a pump?
Old 02-24-2008, 08:17 AM
jentas's Avatar
Looks like I'm ordering the Airdog. Where is the Airdog $450? Cheapest I can find is $500 shipped.
How often do you guys change the filter on these and where are the cheapest filters?
Old 02-24-2008, 08:35 AM
Purplezr2's Avatar
I have an intake, can I even install a fass or airdog.
Old 02-24-2008, 01:22 PM
cumminspower79's Avatar
I voted for FASS even though I dont have one, but I soon will. From all I have read it is a great product and its manufactuer stands strongly behind it. Just look at the thing, It just looks beefy! And it has a great warranty. When I buy one im just going to buy the FASS HPFP w/o the filters. Right now Im just waiting for my third carter lit pump to go out. My lift pump has been relocated to the frame with all 1/2" line and no banjos all the way to the VP. Now I just need a pump that will last longer than 10k miles!
Old 02-24-2008, 08:55 PM
clowndodge01's Avatar
i just installed my airdog yesterday on the stock lift pump it idles @ 9to10 psi now it idles at 20psi and 17 psi if i mash it, i love it and it seems to idle smoother
Old 02-24-2008, 10:38 PM
J Lent's Avatar
Complete system Airdog 150.
PM me.
Old 02-24-2008, 11:35 PM
1BAD4X4's Avatar
Ah, I thought so... I recall now. You PM'd me about it once. Thanks btw.
Quick Reply: 24V Fuel System: Airdog, FASS, or Relocate Stock Lift Pump?
