235 vs 245 Engine
235 vs 245 Engine
What are the major differences between the 235 and 245 engines? I have a 245 with everything on it that the rod bearings are bad in. I also have a 235 that has no accessories. Will all the accessories from the 245 work on the 235 engine and it still run correctly? I'm talking about the fuel pump, turbo, ECM, etc? Basically all of that has been stripped off the 235. Any suggestions or has anyone interchanged parts from the different motors? I know there is a compression difference but wasn't sure what other differences there were.
VP 44 is different and can't be made to make as much power and SO pump.
ECM's are probably a little different too.
I'd repost in 2nd gen performance and accessories for a better view...
Yes everything will work between the 235 and 245 I swaped 1 a couple of years ago and it ran really good cust said it ran better than it ever had I just swapped a 2003 into a 2005 with the 2005 computer and it is a 2005 now runs real good.
These trucks can be modded to make a lot more power. That being said, the VP44 & LP are weak lins, even under the best of circumstances. What do you plan to do with the truck? If it is just hauling stuff & daily driver, I would stay stock or only lite mods. You can spend a lot of $ on these trucks and at the end of the day you have an 11+ yr old truck worth ?
Fix it up to run well and just use it, unless you eally have $ to burn.
I started with a 245 pulled it and replaced it with a 235 auto engine used the 245 ECM on the 235 The 245 had the 53 block and was cracked
RoadDiesel
06-04-2013 12:54 AM
Purplezr2
09-30-2009 07:55 PM
Pro Street
06-07-2005 07:43 PM
