2002 service manual electronic cruise control
I am trying to get my cruise working on a 1998.5 5 spd after transplanting a 2002 powertrain, I believe the 2002 had electronic cruise, I am using the 1998.5 PCM and believe the old vacuum cruise should work but something is not right as the cruise does not power up? If you have any expertise on this subject or a PDF 2002 manual and I have PDF's of 2001, 2003 and 2004 to trade?
I believe the cruise control is the same thru 02, ie the vacuum type.
However I could be wrong because the APPS issue I had went away with the cruise on.
Maybe try asking the WADTR#25 chapter guys in their section to see if a local guy has one available.
SSV1761982
09-04-2013 01:04 PM
orlandfrey
11-03-2004 09:26 PM
