2002 NV4500 5th Gear Nut?
Old 03-30-2005 | 06:21 AM
hotdram's Avatar
Question 2002 NV4500 5th Gear Nut?
A friend at work has an '02 with the NV4500 and tows horses (don't know how heavy he tows). I don't think he reads these boards so he probably isn't aware of the 5th gear nut issue. My question is this: Is the 5th gear nut falling off while towing heavy an issue on the 2002's or was it fixed by then? I would like to let him know if he should think about having it looked at. (I'm also trying to tell him to check his fuel pressure )
Thanks,
~Rob
Old 03-30-2005 | 08:31 AM
Supermod56's Avatar
New Venture did improve the 5th gear nut in 2000(I think), but it is not a fix, they still have issues with it, just not as often.
Tom
2001.5 2500 4X4 5-Spd LB QC Black. Catcher ECM, DD Stage-1's, AFE, Bully Dog 4" pipe, ATS Exhaust Manifold, Silencer Ring MIA, JAKE Brake w/shifter switch, Geno's Banjo's, 3 Autometer's on the A-Pillar, Gear Vendor's O/D, Firestone Air Bags, Redline Oil throughout.
Soon-to-have 14cm Turbo Housing and RASP Pump (Thanks Olee!!)
Old 03-30-2005 | 08:46 AM
CTD NUT's Avatar
Here is some good info on the 5th gear nut problems 5th gear problems and fixes
Old 03-30-2005 | 09:03 AM
4x4dually's Avatar
Great info, NUT!
Old 03-30-2005 | 12:25 PM
hotdram's Avatar
Yes, excellent!!
Thank you.
~Rob
Old 03-30-2005 | 01:03 PM
tool's Avatar
I've never had an issue with the 5'th gear nut on my truck whatsoever. But if I did would it be okay to "limp" home using 4'th or are you going to do dammage?? If the nut fails can you still drive the truck?
Old 03-30-2005 | 01:33 PM
CTD NUT's Avatar
Usually you can drive in 4th.....the tranny operates normally except for the "missing" 5th gear.....the gear typically stays on the shaft but simply slides far enough out of place as to not mesh with the counter gear....
Old 03-31-2005 | 12:22 AM
Big Smoky's Avatar
I thought they fixed it as well untill I was driving down the highway and I went to shift from 4th to 5th and it came loose. I wasn't under heavy acceleration or anything and I never tow in 5th gear. I drove around with only 4 gears for 500 miles. Just get it fixed right and you'll be good. That web site is excellent for fixing the problem. Good luck.
Eric
Old 03-31-2005 | 07:32 AM
4x4dually's Avatar
Trade them in on 6 speeds. I had a 99 5 speed and this 2002 6 speed will pull two of them plus a trailer.
Old 03-31-2005 | 08:51 AM
CTD NUT's Avatar
I would LOVE to have a NV5600.....that definately ain't in the cards, though.....
LemonDodge
09-07-2019 03:51 PM
LemonDodge
09-16-2010 07:33 AM
williala
07-23-2008 05:01 PM
1-5-3-6-2-4
01-25-2007 09:52 PM
wadecool
11-13-2006 12:37 AM
Quick Reply: 2002 NV4500 5th Gear Nut?
