2001 Dodge Cummins / Leaking coolant
Old 01-13-2017 | 06:54 AM
fastlaneharley's Avatar
Exclamation 2001 Dodge Cummins / Leaking coolant
I have a Dodge 2001 24 valve that has begun to leak coolant somewhere at the rear of the engine. It trickles down to the bell housing. Did a pump test on the radiator but still could not locate the leak. Has anyone had this problem before?
Old 01-13-2017 | 09:58 AM
patdaly's Avatar
Not a fun fix............ Could be head gasket, could be the rear freeze plug.
Hard to fix either way.
Leaking coolant from back of engine - Dodge Cummins Diesel Forum
fastlaneharley (01-13-2017)
Old 01-13-2017 | 10:05 AM
johnh's Avatar
head gasket for sure. same area where mine leaked!
Old 01-13-2017 | 12:38 PM
Thank you both for the help. Sounds expensive, but will have to open up the wallet. Truck means to much to me!
Old 01-20-2017 | 12:35 PM
Found out it was the rear freeze plug, had them tap it and install a threaded plug.
nothingbutdarts (01-21-2017)
CumminsRedneck
03-18-2010 02:05 PM
CumminsRedneck
11-12-2009 05:24 PM
gfuller999
14
06-22-2007 04:32 PM
matchhead
09-30-2005 11:55 PM
